Wed, Jan 22, 12:56 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 12:55 am)
Subject: Another shot at the stupidest question :)
Tempest ( ) posted Sun, 19 March 2000 at 6:44 PM ยท edited Tue, 21 January 2025 at 9:55 PM
I was wondering how to apply a morph target. Thanks Tempest
Ghostofmacbeth ( ) posted Sun, 19 March 2000 at 6:56 PM
Well you click on the part that you want to apply the morph to and then double click on it .. there should be something called apply morph ... Wait, just remembered there is a tutorial at Travellers morph world in the tutorial section .. That should help you out S
robert.sharkey ( ) posted Sun, 19 March 2000 at 7:11 PM
Hello Tempest Let's say you want to apply a face-morph. Double click the head of the figure, after that a dialog-box named element properties with a button named Add Morph Target is displayd. Hit the button, a new dialog-box is displayd with the name AddTargetDlog. Chose the button "locate" and a explorer-like window will open. Pick the morph under geometrys/faces folder and double-click. Now your back in the dialog-box AddTargetDlog, give the morph a name in the label-field of this box. now your back in the element properties dialog-box, choose the button OK and your back on the normal poser-screen. On the screen you would now see, the head is choosen on the selecting-wheel. On top you will see the name of the new morph-target (it's the name you had give). Double-click this wheel an a new dialog-box named Edit Parameter Dial is displayd. Set the Value to 1 and click OK. Now the morph is applyed. Hope could help you. SHARKEY The
