Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Hello Tempest Let's say you want to apply a face-morph. Double click the head of the figure, after that a dialog-box named element properties with a button named Add Morph Target is displayd. Hit the button, a new dialog-box is displayd with the name AddTargetDlog. Chose the button "locate" and a explorer-like window will open. Pick the morph under geometrys/faces folder and double-click. Now your back in the dialog-box AddTargetDlog, give the morph a name in the label-field of this box. now your back in the element properties dialog-box, choose the button OK and your back on the normal poser-screen. On the screen you would now see, the head is choosen on the selecting-wheel. On top you will see the name of the new morph-target (it's the name you had give). Double-click this wheel an a new dialog-box named Edit Parameter Dial is displayd. Set the Value to 1 and click OK. Now the morph is applyed. Hope could help you. SHARKEY The
I was wondering how to apply a morph target. Thanks Tempest
