Fri, Jan 24, 5:09 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: What does this error message mean?
TygerCub ( ) posted Thu, 12 September 2002 at 3:25 PM ยท edited Fri, 24 January 2025 at 5:08 AM
After 3 days of sporatic playing without any problems, I finally ran into this screen when trying to load Poser5. I've turned the program on and off several times without this happening... anyone know what it means???
Entropic ( ) posted Thu, 12 September 2002 at 3:37 PM
Something got misread in your .ini file. I'd make a bug report and send it to CL. Beyond that, not sure. I think most XML errors are going to be configuration related, so if you've recently made any changes to the configuration, that might have something to do with it. ;) Paul
Jackmon ( ) posted Thu, 12 September 2002 at 5:09 PM
Try deleting your Poser/Runtime/Prefs/Poser UI Prefsx.xml file. HTH, -Jack
TygerCub ( ) posted Thu, 12 September 2002 at 5:30 PM
Erm... I'm in the process of reinstalling now (too impatient, dontchaknow. But I will try deleting that file if this happens again. Thanks for the help!
TygerCub ( ) posted Thu, 12 September 2002 at 5:52 PM
Okay... DO NOT delete that file. Now Poser won't open at all.
JHoagland ( ) posted Thu, 12 September 2002 at 6:40 PM
Just a thought- are you using IE 6.0? You may want to get the latest version (the one that includes the most up-to-date "XML Parser"). --John
VanishingPoint... Advanced 3D Modeling Solutions
yolkworm ( ) posted Thu, 12 September 2002 at 8:13 PM
What? You mean Poser 5 requires me to upgrade & use IE 6? !!
TygerCub ( ) posted Thu, 12 September 2002 at 8:22 PM
I'm using whatever comes with MicroSerf XP. I reinstalled everything from scratch and realized after the second time there are 2 P5 folders: one is Poser5... the other is Poser 5. You cannot delete either of them (as I did the first time thinking it was my download error). I think this is the same nonsense as the character and characters files found under Runtime.
I can see right now this is going to be confusing as I try to reorganize my files so I can start using all my old Runtime files again.
praxis22 ( ) posted Sun, 15 September 2002 at 11:14 AM
The amusing (or not) thing about all this is that you may need to re-install XP to be able to install the service pack that updates IE6.0 to the latest version: 6.0.2800.1106.xpsp1.020828-1920 according to mine. (I know I did :) later jb
TygerCub ( ) posted Sun, 15 September 2002 at 2:58 PM
I've reinstalled about 10 times (not an exaggeration) since this original post. I kept getting the same message with minor variations between "line 11" and "line 16". Finally, I have a stable P5, but gods above only know what I did to finally get this thing to work. I'll try to stay alert when making changes in the future to see if they affect P5. Very strange.
Jackson ( ) posted Mon, 16 September 2002 at 9:30 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=873270
Brian from CL gave me this...check the link.
