In fact , when I try to save complex objects .obj, several parts made in Amorphium and composed in Vue, it doesn't work (Vue save the object but it never appears in the preview windows). Maybe I should do some tests, trying to see what is the cause (may be due to Amorphium for instance), but I'm afraid it's not interesting for Vue4 users. ;=) Yves
To show your saved objects in the preview window is also very easy to manage. Let's say you have saved your newly created object in a subfolder called OBJECTSINSIDE(or any where else)
Close Vue.
Go in the folder where you have saved your new objects that doesn't show up in the thumbs. Delete the file called "object.prv". Then open Vue and click the OBJECT icon. Look at the folder where you have saved the object (in this case INSIDE) and you will see it:-).
Some more tricks if you need, just ask:-)
and: no problem if you delete object.prv. Vue will create a new one:-)
Guitta
Hi all, I've read the manual and I dind't found any chapter explaining how to merge 2 Vue scene. I made a "main big scene" and want to works on detail to another scene then merge them together. Is there a way other than export as... thanks Laurent
