Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 6:32 am)
When I import the file (pz3), apparently it shows up on the screen as blue boxes spread out. Each box is information of the Poser model features. I thought they were the camera representations, but they're not. I click one and it pops up legs, and gives its morph targets. I click another one and it gives me another part of the body to morph. But there never is an actual figure. Did I skip a procedure?
I haven't had any trouble with Victoria in P5. I understand she won't work in the face room, only the P5 figures will work in there. Not sure what you're trying to do? I also have my entire Poser 4 Runtime in the P5 library. If you try to just load Victoria I suppose you might run into problems because P5 won't know where to look for everything.
Well I made some morph target adjustments to the Victoria 2 Model that I like. And when I go to save it in Poser 4, it only allows it to be saved as a pz3 file. Then I just saved it to my desktop because it's easy access. I want to be able to open the file with all my adjustments made to this figure, since the New Judy doesn't sem to have the flexibility as Victoria 2 does. otherwise I would just start over in Poser 5 with a fresh new model. I've exported in other formats like 3ds, but it's not treated the same as a Poser file. If I place this file in the library, would that work? Would getting it saved as a cr2 help? If so, how would I go about doing that? Poser 4 didn't offer cr2.
I didn't have any luck bringing in models that I'd made adjustments on in P4 into P5, but I've only tried once. I tried saving them as character files first, but P5 wouldn't load them. I ended up just saving them as pose files and redoing the morphs in P5. Hopefully, someone's got a better solution for you.
Can Victoria 2 be used in Poser 5? A while back, Kupa said everything will work, but I can't get Victoria to work. What format should it be put in? The Judy Model doesn't seem to have the morphing capabilities that Victoria 2 does. Or is this a disagreement between the two companies?
