Sun, Nov 10, 6:07 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: playing with zbrush and made this landscape
dolly ( ) posted Fri, 13 September 2002 at 5:03 AM ยท edited Fri, 20 September 2024 at 7:50 AM
Lo all Well this landscape was made in zbrush, and then imprted into vue and used on a terrain i will post the image of the zbrush doc and then you can see the image in the gallerries cheers dolly
dolly ( ) posted Fri, 13 September 2002 at 5:06 AM
http://www.renderosity.com/viewed.ez?galleryid=245967&Start=1&Sectionid=3&WhatsNew=Yes opps there is the link for large image in gallerie lol and here is the image that i made the terrain with using zbrush cheers dolly
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=245967&Start=1&Sectionid=3&WhatsNew=Yes
gebe ( ) posted Fri, 13 September 2002 at 5:13 AM
I have lef a comment:-). This image looks fabulous! The terrain effect is great. Guitta
gebe ( ) posted Fri, 13 September 2002 at 5:59 AM
I wanted to add taht you can download Zbrush 1.23 for free. It is fully functional except the 3D import/export feature. You can use it for longer then 30 days, you just have to ask for a new (free) serial number after this time. It's worth a try. As you have seen you can create terrains and more and export the image (bmp or psd) for use in Vue. Tutorials are included and you find hundreds others for free. Guitta
Caroluk ( ) posted Fri, 13 September 2002 at 1:37 PM
Rimkopf ( ) posted Fri, 13 September 2002 at 6:05 PM
I have tried ZBrush a little and all I have done is a big "gloobb". I understand nothing of it. Perhaps I aimed to high. My first project was a cat...
gebe ( ) posted Sat, 14 September 2002 at 2:34 AM
Learning curve is steep Rimkopf. But there are sooo many Zscripts teaching you every step... Just sit and watch. I'm just a beginner too and not able yet to create a cat. But I used it to create objects for Vue and also morph targets for Mike and Vicky. Guitta
