Sun, Feb 2, 10:03 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: Poser5 Comparision: Am I missing something?
Sherlock ( ) posted Sat, 14 September 2002 at 1:07 PM · edited Sun, 02 February 2025 at 10:01 AM
This is an incremental comparison of all options of the FireFly render. The final shot uses all options including RayTracing. Am I missing something? I don't see much improvement.
aleks ( ) posted Sat, 14 September 2002 at 1:13 PM
are those sleeves only 1-sided? (pic #2) or is it a feature?
Momcat ( ) posted Sat, 14 September 2002 at 1:21 PM
It looks like you have low resolution models, with no textures, and default lighting, and camera. The different settings all do different things. The diffreences are very subtle in this example, but when used for the purposes they were each intended for, you would see more dramatic results.
PabloS ( ) posted Sat, 14 September 2002 at 1:25 PM
From what I've seen/read so far, you're going to have to invest some time in the Materials Room to get Firefly to really shine.
Sherlock ( ) posted Sat, 14 September 2002 at 1:33 PM
MomCat - The scene was rendered with Vicki, Anton's PonyTail, and all with high-res textures. I did use default lighting and camera, but that was intentional for the test.
Momcat ( ) posted Sat, 14 September 2002 at 1:36 PM
I guess this proves one thing. Cl decided to stick with tradition. Looks like the P5 default camera and lighting stink just like the P4 defaults.
wdupre ( ) posted Sat, 14 September 2002 at 1:42 PM
I agree with PabloS the material room is the key. for example none of those Items were originaly set up to use displacement maps, unless you went in and changed them manualy? if you loaded them stock they have to be set up to take advantage of P5's advanced materials settings.
bushi ( ) posted Sat, 14 September 2002 at 1:47 PM
At least two of these options won't show an effect unless you specifically set up the image to use them. Displacement maps are similiar to bump maps exect they will actually move selected areas of the figure to give a much more realistic render. Kind of a bump map on steriods. :) Raytracing is used mainly when you've included reflection or refraction shaders. You also have to check to see that the figures and props have the raytracing option set in their properties.
Sherlock ( ) posted Sat, 14 September 2002 at 1:53 PM
Thanks for the insight, Bushi! I've only had P5 installed a few days and haven't really had time to toy with it until today. Time to read the manual. ;0 } BTW - It's great to know you are still active in the Poser community.
Kiera ( ) posted Sat, 14 September 2002 at 2:05 PM
I discovered in Bryce that turning on all the "premium options" does not necessarily a good render make. This also seems to be true of Firefly. ;)
thgeisel ( ) posted Sat, 14 September 2002 at 2:13 PM
Till my p5 will arrive ,i keep on raytracing in bryce. and the only things a raytraycer can do better than the p4 render, are reflections, refraction and so on... In your image you have none of such, so i think the firefly render give no big improvements. i really want to see a girl in wavy water( and a refleting sword and helmet) rendered with firefly :-))
wdupre ( ) posted Sat, 14 September 2002 at 2:17 PM
"i really want to see a girl in wavy water( and a refleting sword and helmet) rendered with firefly :-))" perhaps in a temple?...sorry.
thgeisel ( ) posted Sat, 14 September 2002 at 2:22 PM
Sorry, forgot the temple:-)) No , i seriously want to see, how the ff render handles such mats
HandspanStudios ( ) posted Sat, 14 September 2002 at 5:11 PM
I think at the Cl website there's a mini explanation of how to set up a reflection. You have to create a new node in the material room, anyway I found it helpful. Maybe try your tests on a closeup eyeball, that should give you a good idea. I was also hoping that just pushing a slightly more expensive 'render' button would do the trick ;-).
"Your work is to keep cranking the flywheel that turns the gears that spin the belt in the engine of belief that keeps you and your desk in midair."
Annie Dillard
timoteo1 ( ) posted Sun, 15 September 2002 at 2:58 AM
the only things a raytraycer can do better than the p4 render, are reflections, refraction and so on... And don't forget REAL (non map-based) shadows. Very key, especially for animators, like me.
wolf359 ( ) posted Sun, 15 September 2002 at 4:14 PM
And dont forget true volumetric lighting and caustics and radiosity of desired.
My website
demosthenes_aborigin ( ) posted Sun, 15 September 2002 at 11:54 PM
whoa! those are straight renders from P5?!? those are as good as (or better than) the best I can squeeze out of ACAD2000's renderengine. Were the objects in some way "solid" or were they the normal Poser 3D mesh skins? If skins, how on EARTH did the program know what to do with the refractory indices???
timoteo1 ( ) posted Mon, 16 September 2002 at 12:42 AM
No there not ... as far as I know, Wolfie's on a Mac and does not have P5 yet. And P5 can't do real volumetric lighting, and has no omni lights, no caustics. I believe these renders are from the all powerful (and heavily Wolf-endorsed) Cinema4DXL. -Tim
demosthenes_aborigin ( ) posted Mon, 16 September 2002 at 1:00 AM
awww, durnit corpus spongiosum rapidly deflating
wolf359 ( ) posted Mon, 16 September 2002 at 5:20 AM
Attached Link: Stargate SG-1
*"I believe these renders are from the all powerful (and heavily Wolf-endorsed) Cinema4DXL."* You guessed it T1, speaking of Cinema4DXL :-) heres my attempt at simulating the "Stargate" from the TV series using primatives and cinemas powerful SLA procedural animated shaders
My website
timoteo1 ( ) posted Mon, 16 September 2002 at 5:34 AM
Wicked! Now just have a Poser figure come leaping through in a burst of light. Very cool stuff Wolf.
