Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=795831&Start=1
I had this happen to me once in P4, the problem in my case was that one of the figures (the first one loaded, if I remember right) had the head as internal geometry. Why internal geometry in one figures head should cause the second figure to loose its head is beyond me. Perhaps it's a crosstalk thing, where the second figure looks for its geometry reference in the first figures head?Open up the cr2 in a text editor and check for internal geometry in the head. Also check that both object references are there. A corrupt rsr might also cause this. The above are tips I got from Bloodsong. Check my original post, linked above.
Save the affected Poser run as a .pz3 file. Using a text editor look in the characters' initial "short actors", e.g. as follows. The missing head's short actor's insides may be missing. Copy it back in from a nearby "short actor", and change the end argument of the geomHandlerGeom line to match. Then save the result as ASCII TEXT, preferably under another file name in the same folder.
<b>actor hip:3
storageOffset 0 0 0
geomHandlerGeom 13 hip
actor abdomen:3
storageOffset 0 0 0
geomHandlerGeom 13 abdomen
actor chest:3
storageOffset 0 0 0
geomHandlerGeom 13 chest
}</b>
...... Kendra
