I made the sword a hammered iron texture I wanted a little more reflection but the settings are very precise and I was constantly overshooting. given time I'll master the material room. with dozens of nodes to pick from and infinite combinations of connections and settings even doing the water was a challenge and I didn't even get that as perfect as I wanted, should have added better refraction. I'm sure that there will be people out there who will do a thriving buisness in P5 textures.
I like to think that my naked vicky actualy uses her sword ;) as for the water and stone materials I started with stock materials and modified them the water was done with the mirror ball material with added transparency and a slight change to the imput texture. I also tried adding a refraction node but didn't have it quite right, that still needs some work. the rock texture was also modified from a stock texture though I made so many experimental adjustments Im not quite sure what they were (I'm not at my home computer so I cant look at it directly right now but I believe I started with the Ice rock.)
![file_23841.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_23841.jpg)
...but there's no temple. I swear I don't even own a temple, instead theres cool raytraced water and stone wall with displacement map. seriously I've never done naked Vicky with sword so I figured I'd get it out of my system.
