Thu, Jan 9, 8:49 PM CST
Subject: Has anyone tried to make conforming clothes for Poser using Maya?
stelhar_1999 ( ) posted Tue, 17 September 2002 at 8:44 AM ยท edited Thu, 09 January 2025 at 8:27 PM
Has anyone tried to make clothes for poser using MAYA? Well I have a question, i made somekind of armor using polygons, I've extruded faces a lot to make some various shapes and give some thickness in the armor. I imported the file (as .obj of course) in Poser and all the extruded faces where somehow bumpy!!!! (like in Maya when you use smooth!) What I do wrong, is there another way to "give" depth to the polygons avoiding the "bumpy" result in Poser? (the same quesion was posted at the MAYA forum)
PhilC ( ) posted Tue, 17 September 2002 at 9:41 AM
It may be because of the way Poser smoothes the faces. Would it be possible to post a screen shot of both smooth lined and texture shaded? We will be able to tell from that.
stelhar_1999 ( ) posted Tue, 17 September 2002 at 5:28 PM
Find out what the reason was or having such a problem, when I started to make the armor I checked the "keep faces together" parameter and went a little on modeling then I closed MAYA to get some sleep (sometimes s*** happens!!!) and whe I opened the file again I din't checkthis parameter again!!!! now works just fine (a little to fine I might add!!!! so how can I keep Poser from smoothing polygons tooooo much????
