Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 10:18 pm)
By default, WinXP puts a firewall on all Network connections. Go to the Control Panel and click on Network connections. Right-click on your Internet Connection and select Properties. I -think- there the firewall setting is within that window somewhere. I can't check myself because I'm using AOL as a temporary Internet solution while the cable is prepped in my area. It's got a slightly different setup. You should see a radio button referring to protecting your connection. That's the firewall. Uncheck, reboot, and reconnect, and you should be on your way. Hope that helps! -Jon
If I understand correctly, you're trying to let P5 get it's own authorization. You could do it manually by taking the challenge code over to the CL site and plugging it in. You have to give some name-address info but you get back the response code which you can then enter in the approperiate box. Takes about 2 minutes all together.
Poser 5 authorized without problem on my XP system. Q#1: when you re-authorize, does Poser 5 reach the screen where it says that it accepted the response code? That is, does it seem like it did authorize, but it is only when you quit, and then restart Poser that there is a complaint? Q#2: Did you receive the automated e-mail from CL, that includes the response code? [another way of checking that the registration process completed okay]. Q#3: does the problem only occur after RESTARTING XP? Q#4: When you select "Help/About Poser", does it show your correct serial number and name? -- ToolmakerSteve
Poser 5 keeps asking to be reauthorized. Has anyone had this problem and/or found a fix for it. Basically, until this problem is fixed Poser can't be used. So far the tech support has been less than helpful, although they may be looking for a solution themselves.
