The only suggestion I can make for this is try backing up the UI folder (under Runtime) and if you get this sort of error again, try replacing that folder with your backup. The error yo're getting seems to come from the XML parser, and all the XML is in the UI folder. Could be that it's getting corrupted. Worth a shot, can't hurt anything, and beats reinstalling. Phoenix
I contacted Curious Labs' tech support about this error. They stated that one reason the XML parse errors occur is if you have a library containing one of the following in the name: quote (") apostrophe (') ampersand (&) less than (<) greater than (>) and possibly... back slash () and slash (/). Their recommended workaround is to 1. Open the LibraryPrefs.xml file in notepad, remove the offending character from the fodler name, is, SM and save out the change. 2. Go to(sic) the Runtime>Libraries>Character folder and remove the offending character from the folder named there too. I sent an e-mail to PFWF (Poser World/Fairy World) regarding this matter since their file names for new stuff usual start with an odd character. Wonder how long it will take for the first Poser 5 patch file?
Have been using P5 for several days until yesterday when it refused to open gave this following error " XML Error: Parse Error:Not well-formed at line 21" Did uninstall this morning and am running again. Anyone know what happened and how to prevent future occurance. Had no problems before this happened. Wolfeagle
