Wed, Nov 13, 5:20 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 11:30 pm)
Subject: How do you save materials?
sharwebb ( ) posted Thu, 19 September 2002 at 5:46 PM ยท edited Wed, 13 November 2024 at 5:09 AM
This is probably a dumb question, but I couldn't find a way to save materials in the manual. Thanks Sharon
atom123 ( ) posted Thu, 19 September 2002 at 6:35 PM
i dont think i totally follow, but poser pz3's will save the material info on files...... also, as far as mats go, YOU ABSOLUTELY MUST download mat pose edit from the free section. it will save you tons of cr2 editing work. that utility makes it a snap to create (and save) material settings..... (honestly, its one of the best things around here 2 get..... i dont know what id do w/o it....)
JeffH ( ) posted Thu, 19 September 2002 at 7:23 PM
In P5 you save them to the library while in the materials room.
HandspanStudios ( ) posted Fri, 20 September 2002 at 3:13 AM
In Poser5 I noticed if you get a node the way you like it and you want to make settings the same for other materials in your scene, you can right click and 'copy', then paste when you go to your next material, then plug the node in wherever it goes. Like when I was making hair and needed the same setting for each hair group, it speeded up the process a lot. There's an 'apply to all' setting but I was scared to try it ;-) having spent a good decade getting everything all set up...
"Your work is to keep cranking the flywheel that turns the gears that spin the belt in the engine of belief that keeps you and your desk in midair."
Annie Dillard
