Tue, Nov 12, 2:08 PM CST
Subject: DAZ has updated Mimic to support Millennium figures eyeblink
Orio ( ) posted Fri, 20 September 2002 at 9:50 PM · edited Tue, 12 November 2024 at 1:59 PM
Attached Link: Mimic page with updates
Hi, I just found out that DAZ has updated Mimic to support eyeblink for many of the millennium figures: - Stephanie - MilBoys - MilGirls - Vicky - Vicky P4 No Michael though :-( (I wonder why) If you're a Mimic owner like me, you'll be very interested in the updates! Hope that Mike can be supported soon, too.
ronmolina ( ) posted Fri, 20 September 2002 at 9:53 PM
Ohhh great! Ron
Dave-So ( ) posted Fri, 20 September 2002 at 9:58 PM
This is great...and what may be even greater...they are doing something with Mimic....not just letting it sit as is.
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
leungpc ( ) posted Fri, 20 September 2002 at 10:58 PM
Hi, Orio: It is a great news. I downloaded the updates but can't get it installed. Could you pls tell me how to install the updates. Thx. Pat
VIDandCGI ( ) posted Fri, 20 September 2002 at 11:20 PM
I wonder if DAZ intend to update mimic as a stand alone application as it is to support either Poser5 andor its own program or whether they will be incorperating it into there own P5-a-like program. At any rate its great to see Mimic has been updated, personally ive been having great fun with it on a couple of projects.
dalliance ( ) posted Fri, 20 September 2002 at 11:39 PM
DAZ went Duh! They forgot the file extention on the updates. Just download the file, right-click it, click rename and add " .exe " to the end. Now it will loak.
EricofSD ( ) posted Fri, 20 September 2002 at 11:51 PM
Saw that the other day when I ordered it. Thought everyone knew. Mimic arrived today, got it installed on P5. Now to figure out how to use it!
leungpc ( ) posted Sat, 21 September 2002 at 12:07 AM
Hi, Dalliance: It works now. Thanks for your help. Pat
Marque ( ) posted Sat, 21 September 2002 at 12:14 AM
You create the wav file that you want to use...you can use any recording program. Start the mimic program. In the top window you will see that you need to load the wav file. Then type in what you said in the wav in the window below. Mimic will do the rest. When you open poser, under the poses you will now see a mimic folder...and inside are your new mimic "poses" that you create. Load up the char you want to use and hit the pose button. I alway turn off the IK when I use it. Then play your animation. Marque
Little_Dragon ( ) posted Sat, 21 September 2002 at 12:43 AM
Orio:
They didn't provide an update for Michael because it's unnecessary. His eyeblink morphs were named properly from the start and already work with Mimic's pose files.
They did forget to include an update for Victoria Reduced Resolution, however.
Michael (MPEG format, 335KB)
gstorme ( ) posted Sat, 21 September 2002 at 3:20 AM
The stephanie one is not working: "No matching files found" It seems they misspelled stephany as stAphany
gstorme ( ) posted Sat, 21 September 2002 at 3:29 AM
Also very strange how different the programs behave, different screen and dialogues for basically the same action to be performed. - For the MilGirls you have to find the file yourself, manually. - For Steph (or Staph :) it tries but it does not work even if I manually select the file - For Victoria2 and Victoria2 P4 it is an all-automatic script.
Orio ( ) posted Sat, 21 September 2002 at 8:46 AM
Has anybody informed DAZ of the "staphanie" problem? I'm sure they'll fix it if they know it. Good to learn that Mike is OK :-) Others have replied to the questions addressed to me so I don't repeat the answers :-)
Dave-So ( ) posted Sun, 22 September 2002 at 12:10 AM
What is this supposed to do exactly? I just tried Vic2 after applying the update...I don't see any difference to the eyes.
diana ( ) posted Sun, 22 September 2002 at 1:05 AM
I had to get the Stephanie update from 3/11 to get the patch to work. The original downloaded version of Stephanie would not work. Maybe that's the problem you are seeing? I got the same message about "no matching files" that you did until I applied the update.
Dave-So ( ) posted Sun, 22 September 2002 at 1:13 AM
well, guess I can forget about that Stephanie update until Monday... Stephanie Update Any one who purchased the Stephanie product prior to March 11, 2002, will need to acquire the update which corrects the EyeSize Morph and makes Minor Adjustments to Skin Material. To obtain this update please contact us at tech@daz3d.com and provide the following information: Full name Current, valid email address you wish to be contacted with Date you purchased the Stephanie Invoice order # for your purchase Desired Platform (Windows/Macintosh) NOTE: Without the invoice number or date of purchase, we will not be able to verify your ownership (please provide at least one of the two). Also, if you do not provide your full name and a valid email address, we will not be able to send you the update ----------------------------------------------------------
PheonixRising ( ) posted Wed, 25 September 2002 at 6:03 AM
This might interest all of you http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=884385 Anto
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
