Wed, Feb 26, 11:06 AM CST
Forum Moderators: RedPhantom
Subject: Question on displacement maps/rendering
Dave-So ( ) posted Thu, 26 September 2002 at 10:12 PM ยท edited Mon, 17 February 2025 at 7:47 PM
Online Now!
I'm trying to use displacement mapping on a character. Are there certain settings that allow it to render, or do I just not have enough ram? What's happening, I tried FF render with displacement mapping checked,raytrace checked...Oh..I did apply a map in the Materials room to the displacement channel :) Anyway, during render, it seems to be stopped...using FF production mode, during the first shadow render, the status bar stopped about 1/3 o the way... I cancelled the render and tried draft mode...the render started right away, but again, it appears to be stopped, this time about 25% complete... Perhaps it just takes a long time... any ideas ??? Should also state, I have some strand hair on this guy as well. I'm not sure how the dsiplacement map min and max affect the render time....I would assume if you put the minimum at 1, there would be more displacement taking place than at zero, or is it the opposite ??
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
JeffH ( ) posted Fri, 27 September 2002 at 9:21 AM
You have to use a map or fuction in the displacement channel. I turned the raptor into a hedge using the granite function attached to the displacment channel :-)
JeffH ( ) posted Fri, 27 September 2002 at 9:22 AM
"You have to use a map or function in the displacement channel."
