Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Not a trick really. It's a program feature that not many people seem to take advantage of. 1.)manually create a 30 frame walk using a quadraped 2.)save the walk in the Poses--> Walk Designer library 3.)open the WD and apply that new slider you just made You'll need to set all the other sliders to a value of 0. And that new walk you created to a value of 100. ScottA
Hi Pixel, If you save a walk to the "Walk Designer" folder in the Pose library. It will automatically be added to your list of sliders in the WD window. You don't need to load anything. However.....If you want to see the preview animation in the WD window as you play with the sliders. You'll need to load that figure into the WD control window. That's what that .pwk file thing is. Just click the "load" button. Then find and select the .cr2 file for the figure you are using in the WD. The Poser guy will be replaced by your new figure in the preview window and Poser will create a .pwk file for you so it can be previewed as you play with the sliders. ScottA
any tutorial for Horse +Camel using walkdesigner?
sometime thre was a trick with ik + something
else that worked - lost the link & tutoial / tip
