Wed, Jan 29, 11:34 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 5:46 am)
Subject: Horse +Camel + quadro? +walkdesigner
holmes ( ) posted Thu, 26 September 2002 at 10:34 AM ยท edited Wed, 29 January 2025 at 11:28 AM
any tutorial for Horse +Camel using walkdesigner?
sometime thre was a trick with ik + something
else that worked - lost the link & tutoial / tip
ScottA ( ) posted Thu, 26 September 2002 at 4:24 PM
Not a trick really. It's a program feature that not many people seem to take advantage of. 1.)manually create a 30 frame walk using a quadraped 2.)save the walk in the Poses--> Walk Designer library 3.)open the WD and apply that new slider you just made You'll need to set all the other sliders to a value of 0. And that new walk you created to a value of 100. ScottA
ScottA ( ) posted Thu, 26 September 2002 at 4:32 PM
Forgot one thing. The IK thing you mentioned may be this: If you want the figure to be able to use the Walk Path feature. It needs to have at least two legs set up with IK. The IK does NOT have to be enabled. It just has to be listed in the hierarchy of the figure. ScottA
pixelwks ( ) posted Fri, 27 September 2002 at 11:38 AM
ScottA I'm interested in this topic also. When you choose the Load button in the walk designer, it wants a file with the .PWK extention. The files saved in library/pose/walkdesigner files are .PZ2 files. Am I missing something?
ScottA ( ) posted Fri, 27 September 2002 at 11:53 AM
Hi Pixel, If you save a walk to the "Walk Designer" folder in the Pose library. It will automatically be added to your list of sliders in the WD window. You don't need to load anything. However.....If you want to see the preview animation in the WD window as you play with the sliders. You'll need to load that figure into the WD control window. That's what that .pwk file thing is. Just click the "load" button. Then find and select the .cr2 file for the figure you are using in the WD. The Poser guy will be replaced by your new figure in the preview window and Poser will create a .pwk file for you so it can be previewed as you play with the sliders. ScottA
pixelwks ( ) posted Fri, 27 September 2002 at 1:15 PM
Thanks I see what you mean now. Your not kidding about how under used this feature is.
holmes ( ) posted Wed, 02 October 2002 at 3:14 AM
hi folks thaks for tips the pose from the library is loaded ok the horses frontleg keep coming out like arms wether ik on or off ??? what does the factory state infulence ? thanks
ScottA ( ) posted Wed, 02 October 2002 at 5:41 PM
Did you set all the WD sliders to 0%. And set the horse WD slider to 100%? ScottA
