Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Looks Great! I hope you will let us all have her? And maybe also make her fit Millie, which I agree DOES make a better name for Victoria than the name her creators gave her ;) Detailer became Painter 3d, and a copy came with Poser, sort of one of those limited edition some portions disabled versions.
Fantastic work! The only criticism I can make is that perhaps the strands look too thick, like spaghetti, unless you were going for a wet look. Who would believe that photorealistic hair in Poser models created by folks here can look just as good if not better than those seen in Hollywood films using proprietary software running on SGI and Sun workstations worth thousands of dollars?
I think you're doing a fantastic job on the hair! Yes, the strands are thick, would work for the 'wet hair' look. I'd love to have this when you're finished! Others might be using it on Posette, but I'm thinking of P4 Male. I need long hair like this for my Shadowclash characters. Good thing that hair can be resized to fit either male or female!
Looks graet, If you can find Painter 3D full version "on the cheap" it is much better then the SE version which came with Poser 4. The big advantage is being able to work with "floaters" wich are similar to photoshop layers. You can turn visibility on/off and nudge them in any direction to see a real-time effect on the model.
