Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 1:04 pm)
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
This sort of thing (auto-rendering) occurs in Poser 4, also (although it hasn't happened to me ... yet). I think it has something to do with the PZ3 you saved, so unless you can track down the problem in that enormous text file and fix it manually, you'll probably have to start over. And that's why I do incremental saves.
Pablos...yes..importing seems to have worked...thanks much :) Wonder what is amiss in the file that causes the render???
Humankind has not
together.
1854
I always, always save before I render, even if I only changed one thing, and for every hour or so of work I save to a new file, ever since poser 4 (pre-patch) corrupted a file of mine for no good reason. Saving before rendering helps clear up virtual memory anyway, leaving more for rendering. (Still not enough for P5 tho...sigh)
oops...it was stated thus: This should be fixed in the soon-to-be-released SR-1 for P5. guess maybe it may be sr2 ?? LOL...we'll hope for 1.
Humankind has not
together.
1854
Another bizarre tale from Dave.... I saved my wip football scene as a pz3. Now, when I load it, the thing starts to render right away...that's cool, I guess, as it gives me a preview of where I'm at... Then I loaded a background image...it was loading the image and started to render again... OK...I have number 99 on the quarterback...or did he get hit so hard the numbers got tattooed on him...anyway, clicked Material tab---rendering started again.... Yikes...hit Pose...render again.... If there is anything positive about the whole deal, I know the scene can render, but it would be nice if it would only render when I chose it to... It appears I may as well delete this scene and start over.
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
