Sun, Feb 9, 9:59 PM CST
Forum Moderators: Staff
Subject: Poser background removal in PSP?
Laverboy ( ) posted Fri, 27 September 2002 at 4:27 PM · edited Sun, 09 February 2025 at 3:46 AM
I have PSP 7....when I render my images i cant remove the background even if i do change the colour to light green. This is especially a problem with the hair. I even tried colour replacer. What do you do?
bushi ( ) posted Fri, 27 September 2002 at 11:08 PM
You might try rendering over black and saving as a .tif file. Doing that will include the alpha channel with the render. You can then make the black background transparent in most paint programs.
EnglishBob ( ) posted Mon, 30 September 2002 at 7:10 AM
Yep... save as TIF or PSD. In Paint Shop, select "import mask from alpha channel". Your figures will then be isolated, with the background transparent; then you can add other layers behind them. There's no need to do anything special to the Poser background with this method.
Laverboy ( ) posted Mon, 30 September 2002 at 9:37 AM
thanks =)
