Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
the Pro version of UV Mapper can do it... if you are trying the grouping tool method, you might try switching document display styles, if you haven't already; you MIGHT find one that will let you get to the flipped polygon. Alternatively, if it is a free thing and not part of something you bought, you can send it to me or tell me where you got it, and I will try and have a go at it, as well. Sorry you are having so much trouble with it...
heyas; okay, a black thing like that is NOT an inverted normal. that's a degenerate facet. the inverted normal will look more like a hole, like in the belt, there. in uv-mapper, the 'fix degenerate facets' button is insert. save your model to a new name after that, in case you don't like the fix. it's rather unclear why degenerate facets occur. i know they can appear on thin or pointy things because poser truncates the vertex coordinates... but when it happens on larger, flat areas.... i've no idea.
