Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Just turn "Control Points" on to modify the mesh by click and move the points. If you want to modify more then one point hold the SHIFT key and select the points you want to modify. Traveler is on Rhino too (so I've heard). He makes most of his morphs in Rhino. I think he can help you more then I because I'm really new in Rhino. The different of Mesh and Face is the Mesh is the whole 3D part and faces are from what a mesh is made of (I hope that was the right explaination) I hope that helps a little bit Regards Chris
"It Is Useless To Resist!" - Darth Vader
Chris you got it right :) PtOn turns the edit points on for a mesh then you can select them there is a lasso command, or you can hold the shift and box select them. Also holding the ctrl key lets you deselect them. You can use almost all of the deformer commands on meshes and points, scale, taper, flow along curve, smooth, etc.
Yes you need OBJto3DM converter to use Poser figures in Rhino. Rhino is really easy to use ( if you know how g ). OK, its OffTopic but whats about a Rhino forum here at Renderosity? Traveler: do you have some Tips for me how to make real good morphs in Rhino? If you want you can email me at c.froehlich@gmx.de . (as I said, I'm new with Rhino) Thanks Chris
Hi, for those who often want to view their models without starting their program or even more than one program (because of unsupported format) check out this utility: 3dexplorer at www.xdsoft.com/explorer/ features: 3d objects and materials browser Internet Explorer style interface Fullscreen mode Open GL hardware accelerators support Slide show mode Thumbnails Automatically viewpoint configuration Separate object controls History of browsed files Built in export features Copy to Clipboard as BMP Open GL C++ code generation 3D Import It is shareware, but the difference between the registered and unregisterd version is thet the latter one shows up reminders at certain times. Benny
Hi, I have imported a Poser human (female) into Rhino. But I don't know how to work upon those polygon. I have read the on line manual, but it's difficult to find a starting point for working upon an existing polygon mesh. Where must I look for? Suppose that I want to change the chest, then how should I start? Btw what is the difference between Mesh and faces they are talking about? Thanx in advance, Benny
