Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
ummm that's a really simple prop...what exactly are you looking for?unless it's for an extreme closeup why not just use a standard poser "box" prop?scale it's dimensions to the right size and shape make it white or whatever color soap you need and viola!,one bar of soap?if that won't do for your needs,post a bit more info,if it doesn't exist already,i'm sure i or someone else can whip out a "bar of soap" prop from 3dsmax or whatever prog pretty quickly,it should take all of several seconds to make a box and round the corners off,bend it a bit or whatever it needs,unless like i said you need extreme detail like indented logo lettering or something this is a really simple shape
Carolly, thanx for the kind words but actually the soap dish is a 'cheat' I didn't have time to model from scratch so I used the shell from my freebie clam cr2, attached a post to it & threw on the default P4 reflection maps :-) As to the bath pearls or bath beads (I've heard both terms used), you could probably use PhilCs' freebie bubbles & adjust the transparency/texture maps to get the right effect
does anyone know where I can locate a bar of soap for poser?
