Wed, Jan 8, 6:29 PM CST
Subject: SR1 problem
saxon ( ) posted Fri, 04 October 2002 at 12:39 PM ยท edited Sun, 22 December 2024 at 10:20 PM
Well, I spent hours downloading it, went to install it and it told me that I haven't got Poser 5 on my system! Brilliant! I even put it into the same folder and shouted look it's there! No good though, silly that it doesn't let me tell it where Poser 5's located....
aleks ( ) posted Fri, 04 October 2002 at 12:53 PM
maybe it's not that bad. imagine what it would do to your p5 if you persued it to take it!
krazik ( ) posted Fri, 04 October 2002 at 12:55 PM
Right click on your Poser.exe and IM me the version reported. -Rylan
saxon ( ) posted Fri, 04 October 2002 at 1:37 PM
It's OK "when all else fails read the instructions". It said re-install so I did that and it installed fine. I was a bit - well, a lot worried about having to re-register with the whole online thing but it re-installed perfectly, didn't ask to go online, and even hung onto my old P4 runtime and the Daz stuff I'd installed. A quick check of the face room - I'd been avoiding that! shows it works well... Feeling a bit daft now....
saxon ( ) posted Fri, 04 October 2002 at 1:49 PM
Incidentally, thanks for the offer of help Rylan (I just looked you up in the manual!). You've helped create a wonderful app. Thanks...
praxis22 ( ) posted Fri, 04 October 2002 at 2:13 PM
What? You have to re-install P5 to install the patch, what kind of madness is that? I've got it, but I'm holding off installing it given the number of reported problems. later jb
c1rcle ( ) posted Fri, 04 October 2002 at 3:28 PM
looks like you only need to reinstall if the updater doesn't see poser5, run it, if it sees poser5 you're ok
praxis22 ( ) posted Fri, 04 October 2002 at 5:38 PM
But why doesn't it see it in the first place, it's not reading the registry or what?
doldridg ( ) posted Sat, 05 October 2002 at 5:05 PM
From the complaints I'm seeing, it seems to only look in the "usual place." Maybe that's why I had no trouble. I installed P5 where it wanted to go instead of in a special folder like my P4.
