Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 10:34 am)
This would be more productive if you posted the actual problems you're having with P5 and also contacted CL about the problem. And before you hit me with the sheep label, I've said many times in this forum that I've had problems with P5. I also contacted CL, filled out a bug report, tried some of the suggestions posted here, and sent the results to CL to help get the problems fixed. I'm going to try out the patch tonight and see if that helps my P5 issues. If it doesn't work, I am going to be POed, and I'll post the results, but I'll also contact CL and see what can be done to get it fully fixed. Posting several variations on the same picture expressing your displeasure is not helping get P5 fixed on your computer.
