Fri, Nov 29, 6:48 PM CST
Subject: P5, How To Hide An Object?
GraphicArtist88 ( ) posted Fri, 04 October 2002 at 8:44 PM ยท edited Fri, 29 November 2024 at 4:13 PM
Ok, maybe i havent spent enough time reading the P5 manual, or maybe i just learned manuals dont tell you want you want to know anyway. But in Poser 5 how do you hide a piece of an object in the materials? For example, i downloaded the Football PAck from Daz3D and I want to disable the stripe on the side of the uniform pants, but cant seem to make it "in-visible" form object properties and cant seem to hide it by setting the properties dials. Someone have any ideas? I want to make a custom texture using the map, but there is not one for that darn stripe. Thanks!
depakotez ( ) posted Fri, 04 October 2002 at 8:52 PM
Well you could make the color/mat settings the same as the pants. Or if you want invisible turn transparency and edge to 1.0 Tom
GraphicArtist88 ( ) posted Fri, 04 October 2002 at 9:01 PM
I thought about making the mat and color the same as the pants, but some NFL teams have custom stripes on their pants and i want to try and be as accurate as possible. I set the Transparency and Edge to 1 and although the color of the stripe goes away there is still a obvious shadow line of where the stripe used to be.
GraphicArtist88 ( ) posted Fri, 04 October 2002 at 9:19 PM
Thanks Depakotez,
I applied the texture from the pants with the stripe in place and it lined up. Thanks!
depakotez ( ) posted Fri, 04 October 2002 at 10:41 PM
No Prob. Though to help get rid of the shadow you have to reduce the specular/highlight to 0 value with black color. Then trans falloff to 0 as well. :) Tom
EricofSD ( ) posted Sat, 05 October 2002 at 1:44 AM
If you want to hide an object, and if the group is sufficiently broken into parts, you can use the heirarchy editor to hide.
depakotez ( ) posted Sat, 05 October 2002 at 12:18 PM
Yeah all this was if it was a material only. The easiest way is what Eric said. Tom
GraphicArtist88 ( ) posted Sat, 05 October 2002 at 12:22 PM
Thanks, UNfortunatly the stripe was not in the hierarchy menu when i went, so i just set the material the same as the pants and lined it up. I am still working on it, but here is what i have so far!
