Tue, Feb 25, 8:32 PM CST
Forum Moderators: RedPhantom
Subject: Help me! SR1 Problems
Karma ( ) posted Sat, 05 October 2002 at 7:47 PM ยท edited Wed, 12 February 2025 at 4:16 PM
I installed the patch, now I can't access my parameter dials. I've also tried to hit control-I and select it from the pull down menu and it will not appear on my screen. I have also tried to uninstall it and just use poser 5 without the patch and still have the same problem now.
Tirjasdyn ( ) posted Sat, 05 October 2002 at 8:29 PM
What is your monitor resolution? Did you get the new version of the patch? The uninstall might not help if the registry settings were not removed.
Tirjasdyn
gryffnn ( ) posted Sat, 05 October 2002 at 8:51 PM
Didn't someone have a problem with it being off screen? You can try to old Poser 4 trick - select Edit, Preferences and then reset to factory settings, and see if it shows up.
