Sun, Feb 9, 3:14 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 1:04 pm)
Subject: Poser 4 problems
Jilly ( ) posted Mon, 07 October 2002 at 1:15 PM ยท edited Tue, 04 February 2025 at 8:48 AM
Hi, I have Poser 4, and just recently have been having trouble when trying to use, say, Sergmarks stuff, I keep getting "Violation in C: blah blah blah," or "you're out of memory", this may seem a tired problem for you experts lol, but I'm nowhere near that quality! How do I remedy this ( apart from not using Serge) Jilly
queri ( ) posted Mon, 07 October 2002 at 1:20 PM
Do you have the 4.03 patch? That usually takes care of Violation C matters-- downloadable on the Curious Labs site. Emily
c1rcle ( ) posted Mon, 07 October 2002 at 1:21 PM
sounds like the obj files have gone walkies, open the cr2 file in your favourite text editor, about the 3rd-4th line down is the path to the obj, if the obj file isn't in the directory mentioned you'll need to either move it to the directory or change the path in the cr2 to match the directory it's sitting in
hankim ( ) posted Mon, 07 October 2002 at 11:10 PM
If you've done both of those things and you still get "you are out of memory" message, it could be that the *.rsr in the geometry is corrupt. Just delete the one from the proper geometry folder -- NOT the one from the figure library. If that is the problem, the item should load okay next time, and Poser will take it upon itself to create a new rsr for the geometry :-)
