Mon, Jan 13, 2:22 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Carrara Free Stuff here.
Subject: REQ: Tutorial: How do I create MorphTargets with Carrara?
stonecold ( ) posted Wed, 29 March 2000 at 7:45 AM · edited Mon, 13 January 2025 at 2:19 PM
Can Carrara do this? Can anyone help me out? Is there a tutorial? So many questions - I hope there will be answers... Stonecold
pack ( ) posted Wed, 29 March 2000 at 8:45 AM
Great question. Hope you get an answer. I would like to know too.
arcady ( ) posted Wed, 29 March 2000 at 10:48 AM
It's not too hard really. I assume Poser Morph targets? Export and obj file from Poser. You want to export only the part(s) of the body you plan to morph. So uncheck everything else in the hiearchy editor... So far you should be doing the same stuff you do to make a morph target for any other application... To bring it into carrara you just open the obj file in Carrara. There's an option on the list of options that says '(needed for morph targets)'. I forget what the first half of it says and I don't have Carrara here at the moment... But it's the only option you want checked other than the default options that are already checked. Bring it in, select it and move to the modelling room. Don't add any vertexes. Just use the sphere of attraction tool. When you've got the shape you want export it to an obj file. You can use it as is as a morph target in Poser. The shape you made is the 1.0 setting on the dial. You might also want to open the obj file and remove all the lines that don't begin with a 'v'. This will cut the file size by as much as 2/3. WHich is a real good idea for memory and upload purposes.
Truth has no value without backing by unfounded belief.
Renderosity Gallery
pack ( ) posted Wed, 29 March 2000 at 11:22 AM
when moving the bodypart to the modeler window it says No Parameters in a blank window. Had this problem before. I was hoping to see my mesh or something in the modeler window. Whats up. I imported the obj, then selected the object in the assemble window first, then moved to the modeler window. advise?
arcady ( ) posted Wed, 29 March 2000 at 2:08 PM
When I get home tonight I'll look at the steps I used more closely and put some statement together. The error you got sounds like it wasn't selected, but you say it was. So I'm not sure off hand.
Renderosity Gallery
arcady ( ) posted Thu, 30 March 2000 at 12:56 AM
Well I've made a bunch of screenshots. I'll have a tutorial ready sometime tommorow most likely.
Renderosity Gallery
pack ( ) posted Thu, 30 March 2000 at 7:51 AM
Forget it now, you're too late. Just kidding. You are too kind. Thank you much. I work around 60 hours/week, so reading manuals from the beginning is a dream (of many) I hope to reach some day. Problem is I have about 10 manuals.
