Fri, Dec 20, 8:20 PM CST
Forum Moderators: Staff
Subject: Problems with some Japanese characters.
Torulf ( ) posted Sun, 06 October 2002 at 11:02 AM · edited Fri, 20 December 2024 at 4:32 PM
I am having problems with some downloaded Japanese manga/anime style characters in poser4. I cannot get the face expressions and morphs to work. I have these characters: Motomoko, Onioko. Misuzi, MA3, Oyaji, Sonoko In some of them there are several OBJ files. I do not know how to use them. I have tried to use them as head morphs but that does not work. The readme file is in Japanese. Is the Japanese Poser different from the english version? Torulf
TG
Spitfire ( ) posted Thu, 10 October 2002 at 9:47 AM
Hi, Torulf Did your Poser give a message to locate the OBJ Path? In this case, 2byte-code(Japanese Caharacter) is used in cr2 file. But don't worry. Then You should change the OBJ path in cr2 file with single byte code( of course, OBJ file name too). I have Poser403(English Version), and I am Japanese. I will check these files, if you want. Please tell me the URL which you got these MTs. See you,
Torulf ( ) posted Thu, 10 October 2002 at 8:16 PM
I have found most of them on this site. http://www.geocities.co.jp/SiliconValley/2619/ Im grateful for help. Torulf
TG
Spitfire ( ) posted Fri, 11 October 2002 at 9:48 AM
Hi, Torulf I have download manga figures and check them. Readme file(written in Japanese) saids, these OBJ's are only suit for each manga figures. So, you should not apply these MT's to other figure. In the other hands, I could open these figures in my Poser403(English Version), so, you can use these managa figure itself. In addition, MT's are already applyed to each figure, so you need not to apply again. Sincerely,
