Forum Moderators: Staff
Hi, Torulf Did your Poser give a message to locate the OBJ Path? In this case, 2byte-code(Japanese Caharacter) is used in cr2 file. But don't worry. Then You should change the OBJ path in cr2 file with single byte code( of course, OBJ file name too). I have Poser403(English Version), and I am Japanese. I will check these files, if you want. Please tell me the URL which you got these MTs. See you,
I am having problems with some downloaded Japanese manga/anime style characters in poser4. I cannot get the face expressions and morphs to work. I have these characters: Motomoko, Onioko. Misuzi, MA3, Oyaji, Sonoko In some of them there are several OBJ files. I do not know how to use them. I have tried to use them as head morphs but that does not work. The readme file is in Japanese. Is the Japanese Poser different from the english version? Torulf
TG
