Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
I am not sure about P5 since I haven't purchased it yet, but I have had the same problem in P4. I find the obj files that have large flat planes or nice square edges always ballooned (additional smoothing) on import. But, I have learned that 3ds files always come in nice and clean with no or minimal ballooning. Perhaps you can take your model and convert it to 3ds and re-import it, then resave your prop to the library or to an obj file.
My python page
My ShareCG freebies
thgeisel > Some more, the same props used with p4 render behave total normal.And since the SR1 patch i cant turn off smoothing for seperate props in the properties window. Err, since SR1 I can turn it of and one for each object. Maybe the sum of bugs is constant, the patch only shifts the bugs from one user to another. ;P
My python page
My ShareCG freebies
My python page
My ShareCG freebies
Note: the odd triangle on the bottom is not P5's fault; that seems to have been done when I converted BMP to JPG in a separate paint program.
My python page
My ShareCG freebies
Had the football helmet bought in RMP, with smooth on, the vertical bars in the face mask literally did look like balloons. After many test renders, tried with the smoothing off, and bingo, it looked like a face mask again. Haven't tried to re-render post patch yet, but the balloon affect was the only difference I could tell with smoothing on/off.
There are other things that Poser 5 doesn't like : shadows. I have a strong enough computer (for a non professional) and I have installed the SR1 patch. Everything runs smoothly in Poser 5 and in the Firefly renderer as long as I don't ask it to calculate any shadow. If I click on the "shadows" option in the render options, then the rendering slows exponentially and finally freezes, sending me a "C exception". That's quite exasperating to see that Curious Labs sells a non working product, and even more to see that they don't answer to my e-mails, not even to say "OK, we'll work on this one". I'm begining to consider going back to Poser 4... As for polygon smoothing, it was one of the main reasons I bought Poser 5 : I wanted to have pictures of humans that looked natural, and not with polygonal shoulders. I hope that CL will fix all the bugs quickly.
May sound a bit stupid,but after some observation there are props that poser 5 ( specially the firefly doesnt like) Im on a amd 2000xp,768 mb ram......so no weak system and p5 is running smooth.i can use the mildragon and a viccy with clothes all no problems. But if i use only some more or less simple props( nothing else) and start render(same settings as before) poser slows down,starts swapping to hd like crazy,rendering slows down.....and mostly never finish This only happens withsome props,and till now,they have something common, the geometriedata is included in the pp2 file and if i start render with smoothing enabled they look like gasballoons. smoothing enabled make them look normal,but the renderspeed is not improved and the same as above starts
