Wed, Nov 27, 9:16 AM CST
Subject: Problems with the Mil Dragon in 3D's Max
designerin ( ) posted Thu, 10 October 2002 at 11:49 AM ยท edited Fri, 02 August 2024 at 11:21 AM
I have some Problems with the Mil Dragon(full Version). I export the Scene from Poser Pro to Max, no Textures or Transmaps applied. But I can't see the Wing Membrane in Max. In Poser i can see the Membrane after rendering it, not before. So is it a Bug from DAZ, Poser or Max?
Virus ( ) posted Thu, 10 October 2002 at 12:49 PM
Nope not a bug on any of those aplications, the wings membrane are 1 side face mesh in max, change the wings material to double sided.
SAL9000 - Hello Dr. Chandra, Will I've dream?
aleks ( ) posted Thu, 10 October 2002 at 1:01 PM
or do "force 2-sided" in render window.
designerin ( ) posted Thu, 10 October 2002 at 1:04 PM
Thanks, that was it! Great Problems, simple Solution :)
ar2g ( ) posted Thu, 10 October 2002 at 1:35 PM
Cool!! I had this problem last night and was just about to ask how to fix it. Thanks folks!! Now how does one get the bump map to show up? Thanks, AR
Virus ( ) posted Thu, 10 October 2002 at 1:52 PM
AR if your bump map is not showing in the skin's material, you can add it at the materials editor, go to the bump map and select bitmap, then go to where you have stored select it and voilthat's all, maybe you will going to need to change the value, Max alwas use a 30 % as the default value for a bump map, play with that value and use what you like it better.
