Thanks for the terrain tip (great tutorial project) ! Recently, I saw a work of Alekssander (Aquarium) with smooth edge furniture made with only boolean operations and primitive objects. Awesome modelling work, looking very real. The problem is probably the texturing work , if you use image mapping for all the objects, it could be strange looking at the end : it should be easyer to use procedural textures for such models. Interested to see your opinion. ;=) Yves
Okay... here's the question I have and perhaps a good challenge as well. Is there a way to create a bump map in Vue that would also effect the edges of an object, like a cube or a cylinder so that they are no longer smooth? For example... Take a cube and make it look like a rough brick only with the edges where they are not sharp... to where it looks like a real brick. Can this be done using just bump maps without having to alter the cube what-so-ever? If so... how is it done... if not... is there an easy way of doing it? -=> Jim! <=-
