Mon, Feb 24, 10:28 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 1:37 pm)
Subject: The P5 Hairroom. Natural hair please.
DazzeKnall ( ) posted Sat, 12 October 2002 at 11:33 AM · edited Mon, 24 February 2025 at 10:18 PM
How can I make smooth long hair that falls naturally on the shoulders in Poser 5s hairroom? I believe it's a matter of getting those settings right but so far I've only been able to make messy hair that looks ugly and doesn't follow the law of gravity. Has anybody any experience with this matter?
EricofSD ( ) posted Sat, 12 October 2002 at 7:06 PM
Yeah, play with the settings starting on the left. length, pulling back and to the side, etc. If you are getting wavy hair, reduce the kink strength etc. But the row of sliders to the far left are the most important for what you are describing. Pull down helps a lot with the law of gravity.
DazzeKnall ( ) posted Sat, 12 October 2002 at 10:19 PM
So you have had some succes. Do you have an example of what you have been doing?
AprilYSH ( ) posted Sat, 12 October 2002 at 11:50 PM
i called it ShoulderLayers! well, i used hman's skull cap in the poser5 library and made 7 groups and grew this hair as a simple test :) it was quite simple afterall... it's doing more complex styles that will get me thinking. and it just took long to render the 4th time, there's a memory leak going on. :/ follow the manual instructions and you'll do fine. :)
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
Dave-So ( ) posted Sun, 13 October 2002 at 12:57 AM
Also...use the styling tools... You can pull the hair all the way from the roots..using the tip to root slider....experiment with that. I set the slider all the way to root...then stroke the selected guide hairs, starting trom the root straight out...you can rotate the head to get the direction of the pull correct...you can make the hairs pretty much straight this way...then slide the slifder toward the tip setting..you can twist, curve, pull, and so forth and make the hair do just about anything...but save when you get to a good looking point prior to tweaking, because it sometimes goes haywire :) Be careful
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
DazzeKnall ( ) posted Sun, 13 October 2002 at 1:18 AM
I know I can style me through the problems. I've tried that myself. But I want to be able to let the hair fall, using the dynamic collision-detection to get a natural-looking result where hair is lying on the shoulder, not penetrating the geometry. Thanks for your replies though.
