Forum Moderators: RedPhantom
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
Also...use the styling tools... You can pull the hair all the way from the roots..using the tip to root slider....experiment with that. I set the slider all the way to root...then stroke the selected guide hairs, starting trom the root straight out...you can rotate the head to get the direction of the pull correct...you can make the hairs pretty much straight this way...then slide the slifder toward the tip setting..you can twist, curve, pull, and so forth and make the hair do just about anything...but save when you get to a good looking point prior to tweaking, because it sometimes goes haywire :) Be careful
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
How can I make smooth long hair that falls naturally on the shoulders in Poser 5s hairroom? I believe it's a matter of getting those settings right but so far I've only been able to make messy hair that looks ugly and doesn't follow the law of gravity. Has anybody any experience with this matter?
