Forum Moderators: Wolfenshire, Deenamic Forum Coordinators: Anim8dtoon
Animation F.A.Q (Last Updated: 2024 Sep 18 6:34 am)
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
11 Second Club: Monthly character animation competition.
Animation Mentor: Online school. Learn from the animation masters.
Rigging 101: Maya rigs and rigging tutorials.
AnimWatch: Showcasting the best of independent animation.
FlashKit: The best place to learn Flash.
Armaverse: Stop-motion armatures for animation.
60+ great Character Animator's sites: Get inspired.
I've experienced that problem when using certain formats. You can try recompresing the file with VirtualDub. It's a simple encoder that supports any thinkable format and the output comes out pretty good.
nemirc
Renderosity Magazine Staff Writer
https://renderositymagazine.com/users/nemirc
https://about.me/aris3d/
I feel your pain. I'm trying to do something similar 720x480 poser animation to run on your home DVD player. Getting information on how to do this is piece meal and incomplete. No wonder there is so little work getting out. We need a one stop info source. I spend my time trying to figure out codecs and fields and compression schemes etc. when I could be animatin - it's hard enough all on its own.
Only render to the size you want for the final use. If you render smaller then you want, it will always look blocky, and pixellated. Cinepak is another OK format, that any machine can play back. If you want to use MEPG, get a better encoder then the stock one in Premiere. I output to uncompressed, then toss the file into Cleaner for my encoding, but it is a little pricey. The best use for MPEG is if your going to DVD. Then of course, you'd be using MPEG 2.
I am trying to make a 3d movie, using Bryce and Poser4. I want to run a large movie on an 800x600 full screen. I use a PC 900MHz, 560MB ram. There are several questions about size format compression and more. I have tried this way. Render raw AVI 640x480. Edit and compress in Premiere 6. Store it at the hard drive. I have tested several types of compression, like MPG. I play it from the hard drive using Win Media Player. I plan to burn CDs and play it from a CD. The movie does not flow, but hacks and moves slowly. It works better if I use 480x360, but its still not perfect, and if I run it full screen it becomes blurry and pixelized, especially if I use MPG. I would be grateful for advice and tips. Are there some useful tutorials? Torulf
TG
