Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
I am really not the one to be asking, but here is a cut and paste of an earlier thread by jschoen on 03/28 that I believe outlines the necessary steps for exporting the morph as well as reducing the overall file size. ------------------ Cut and Paste ------------------------ 1: Set all dials to Zero. 2: Set the morph you want to the setting you want. 3: Select the head and "Export" as a WaveFront Obj 3a: When requester comes up, deselect ALL (including the "Universe" 3b: Select the "Head" only. Do NOT include the Eyes. 4: Select OK, and when the next requester comes up, again deselect ALL, and select Save as Morph Target Only. 5: Now open up the new Obj file in a word proccesser. 6: The top section will be all you need. ( All the lines starting with a single "v" 6a: Remove everything below this or any line that does NOT begin with a single "v" 6b: Note/TIP: The next set of commands start with a "vt" do a serch from top for "vt". Everything below and including the "vt" lines are not needed. Remove. 7: Save this as a new file (different name -- always keep originals) That's IT. A 1.5 meg file down to around 300k Now open Poser select the figure you applyed the morph to origionaly. "Get info" "Load Morph target" Hope this helps. And is correct, this is what worked for me James ------------------------------------------------------------ Hope that works Pam. If not maybe James or someone else here who has actually done this before can help out with the instructions. I would love to get this face. I think it is great! Rob
Pam, this image is stunning. She's not the Barbie Doll cute that some of the P4 characters have been. She's really more what they used to call in the "old days" as a handsome woman. Actually, she's quite pretty in your render. She would like nicer with hair framing her features. I'm having trouble getting the texture map for Vickie, but Zygote in on the job trying to fix it. Can't wait until I can start using her. Melanie
Pam, tried the Ann morph out and it worked okay. I did not have any problems like DianeB mentioned. It might be a conflict with another morph target. I just unzipped Millie and your morph was the first I put on - the only other thing I did was make sure that I zeroed ever dial on the face perimeter before I applied the morph. Hope that helps. Many thanks again. Now I don't mind looking at Millie so much - her face anyhow. Next I have to work on her body. LOL Rob
