Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Attached Link: Poser 5 beta test forum
There seems to be a problem with Poser 5 shader tree or the way it interprets tranparency, I'm not sure which. Check this thread started by Jelisa in the Poser 5 beta forum, and see if it's similar to yours. http://www.renderosity.com/messages.ez?ForumID=12440&Form.ShowMessage=915991 It's actually worth checking the beta forum for similar problems because they might even have the solution there or it could be there isn't a solution without a patch. Not saying "don't ask questions in here" that'd be daft, but take a look in there to see if there's anything like your problem and if not, come on in and see if one of those with a perfect copy can help you. :)This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Is there any guidline you can follow to set the transparency settings in Poser 5 so that they appear the same in a render as they did in Poser 4. Poser 5 trys to set the values for transparency when you pull in a Poser 4 saved file but the results are not the same (Even if you set your renderer to Poser 4 with out shader trees). I'm not talking about fall off or the edge setting but the actual amount of transparency does not seem to be enough to get the same effect in Poser 5. Anybody know how the new Poser 5 settings correspond to the Poser 4 ones? Thanks, Thorgrim
