Mon, Feb 3, 5:22 PM CST
Subject: Animation Question
arrow1 ( ) posted Tue, 22 October 2002 at 5:45 AM · edited Sun, 26 January 2025 at 1:11 AM
I posted this question in the animation section,but I didn't recieve a reply,perhaps someone here might help.I am learning animations, with poser, and have successfully posed a figure, which I want too fall down slowly to its knees from a standing position , turn away from the camera and fall flat on its back or side.What my problem is I want to slow the animation down.The first part falling to knees,is a a total of 15 frames at 30 frames per second.It falls too fast and is also jerky.I can't understand the Poser 5 book the way it is written.Can someone explain to me in plain terms so I can solve this problem. arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
geep ( ) posted Tue, 22 October 2002 at 7:08 AM
You will need more frames.
At 30 fps your action (of 15 frames) will take place in 1/2 second.
You can change the frame rate by clicking on the little down arrow ...
(next to the small fps window in the Animation Palette)
(or click on the fps number to change it)
... and selecting 15 fps.
Now your action will take place in 1 second.
Still too fast? .......... Do this...
Using the Animation Palette (or the Animation Controls), click on the "total frames number"
("Frame XXX of YYY")
(click on the "YYY" value and change it to 60 (or whatever else you want.
If you want the action to take place in 4 seconds (at 15 fps) you need a total of 60 frames (4x15=60).
After you have changed to total # of frames, you need to "retime" the animation.
Make sure that "Figure 1" (or whatever name it has) is selected (the "Body").
Now do this ...
[menu] "Animation" ---> "Retime Animation..."
Now in the "Retime Keys" window ...
change the destination frames value to 60 (or whatever value you want) and hit "OK".
It should look like this:
"Source frames: 1 to 15"
"Destination frames: 1 to 60"
Now play your movie and it will run 4 times slower.
  • or -
If you use 30 fps and have a total of 60 frames, your movie will run 1/2 as fast or it will be "half-fast."
(sorry, couldn't pass that one up)
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Tue, 22 October 2002 at 7:24 AM
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Tue, 22 October 2002 at 7:25 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Tue, 22 October 2002 at 7:34 AM
If you have more than 15 frames of action in your animation ...
... make sure you "Move" the remainder of your animation "over" to some empty cells ...
(after you add more frames to your movie)
... and BEFORE you "retime animation" or it will overwrite some (or all) of the remainder of your animation. (and you will lose it)
Hmmm??? Looks like maybe I should do a "Primer" on this one, also.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Dale B ( ) posted Tue, 22 October 2002 at 7:41 AM
Geep.... YES!!! I've just gotten Mover for Vue, so I could start playing with Poser animations outside of the box, but really need some simple 'how to not' instructions, as I learned =real= quick just how unforgiving the Poser animation system can be. Fortunately, I believe in backups.... :P
arrow1 ( ) posted Tue, 22 October 2002 at 4:42 PM
Many thanks,I will try your suggestions this evening.arrow1
geep ( ) posted Tue, 22 October 2002 at 5:35 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=922474
You might want to tune in to THIS ONE! cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
