Oh, and I turned the shadows off for the left hand light.
Tjohn, You must have gremlins in your computer. :) That tapped in nail is really awesome, it's about the first thing I noticed. I agree it helps add depth. I like these nails much better, they look more like the nails I've used. The hammer looks a lot rougher and older too. Something about the handle of the hammer puts me off of thinking it's a photo, but I can't quite put my finger on what the problem is. One other little problem, the second nail up from the bottom on the left of the picture has a slightly messed up tip. I can see where the cone breaks off from the cylander. I think you are getting awfully close to realism here. Well done. Lin
Lin: I see what you mean, but the nail is only messed up in the "gag" version, not the "real" one. This is weirding me out, because I "plop" rendered the Eyebis into the pic, I didn't rerender the left side of this pic at all (hums Twilight Zone theme).
Unfinished plywood has texture in the form of bumps (non-smooth). I would also try to sharpen the knots, the texture you use is a bit too on the blurry side. It should be as focused and sharp as all the other items in the FOV. The other issue is the bottom end of the hammer handle. It seems too faceted. need a smoother mesh or some post wrk. Definitely getting there.
Attached Link: http://perso.club-internet.fr/lemog/lemog_textures/acc_textures01.html#
I've seen that gremlin around the place - but where does it come from? I want to play with it too..... Nice nail, btw. I think something that would help you achieve photorealism is a bit more bump on the wood - it looks a bit like formica the way it is, rather than wood with a texture. I found a wonderful texture resource at the link above - do investigate it - I'm addicted to the textures from there!i dont whant to hurt you but, thats not even close to photorealism, a hammer head does not look like that, its made of metal and not specular stone, to get that aged look add rust, that sould be bryce5 if u use dof so why dont u use the soft shadows option? why dont u add a texture to the nails? perhaps there is one but to me they look flat grey= not photo real. and for one last thing if you did show the end of the plywood or the heriozon and then added some more dof it would be more "Real". and a smal trick could be to make it B/W and add grain.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=266082&Start=1&Artist=tjohn&ByArtist=Yes
Thanks for the great suggestions. Several artists ask about bump maps. Believe it or not there are bump maps on every single object in the pic. With a size reduction to 800 x 600, a little detail was lost. Here is a link to the 1024 x 768 version in the gallery (I think it makes a good desktop pic). I think the textures on the plywood look pretty much like the surface of rough unfinished plywood, at least the way I remember it, but my memory isn't as accurate as it used to be, so... There is a Brycean 5 dof blur, a subtle one, perhaps, but look at the back, and you can see the blur. Maybe this is also feeding the comments about blurriness of some textures. Well, a very wise person known only as "hewsan" once told me, "all work is a work in progress till you tire of it." Truer words were never written. But there's a good chance I'll return to this image to tweak on it some more, I do that a lot. And I'm saving this thread so that when I do I'll have some good suggestions for improvement. Thanks all! Oh, I almost forgot about Eyebis (the Gremlin). I'm glad so many people like him (it?). I've been drawing Eyebis since grammar school (you see, I've always been like this). His first 3D incarnation was on the Amiga with a program called Imagine. The latest one is 100% Bryce5 with metaballs, spheres and cones. I like him so much I use him as a sort of mascot on my thumbnails in the gallery.This is not my "second childhood". I'm not finished with the first one yet.
Bryce Forum Coordinator....
