I don't really know lol I didn't check! I just was pointing out that you could get a half decent pic with the 512 size. I'll have to check and see :)
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
Some wrinkles were on the guys pic, and then I used the transform dials to add some, I also checked use displacement maps, and set it at .200 I think. The wrinkles above the nose bridge were on the guy and the ones on his cheeks coming from side of nose, I think the displacement map made them show up better, and those are the ones I said needed softened a bit. and the little scar on the chin was on the pic also.
System Ram: 8GB
Lapis, I don't see anything in the readme that says you can use a bigger texture in the face room, but you could use the small ones to get the face shape, then apply the larger ones in the materials room :)
System Ram: 8GB
jer I'll post the image although I used random face on this one so it doesn't really look like the man. give me a sec to post it.
System Ram: 8GB
System Ram: 8GB
I like the face room a lot and think the textures it generates are as good as the pictures you input. You obviously used a real good picture. Two tips: Judy has morphs that widen the nose and narrow the nostrils, among others, that Don doesn't have. Copy them over to Don, the geometries are the same. Also, do post work on the face room textures. For example, copy the eyebrows from the original pic and lay them over the texture. It works well.
Thanks All :) and Marque, I only used the texture, I didn't try to make him look like the guy ;)
System Ram: 8GB
squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak squeak lol Marque
System Ram: 8GB
