Carrara F.A.Q (Last Updated: 2025 Feb 10 2:42 pm)
I found out if I check the load as one obj, it loads in fine. I tried the rds format, and I get strange breaks in the vertices and no tex maps. Speaking of maps. My next thing is to figure out these damn transparency maps from Poser to Carrara. I tried all the ways shown on this board. Still no luck. It should be simple. James
to load a poser figure into carrara (I use the updated Mac version) I export the poser 4.02.118 figure as an obj ** (default settings) to a folder that contains ALL the maps associated with the figure and which was used to load the textures to the original poser figure. Then I import the wavefront obj file into an existing scene in carrara using the default settings. To check that ALL the maps are in the folder, read the mtl or mat file as a text file to confirm that the paths referring to each map go to the folder and that all the maps called by the mtl or mat file are in the folder. I guess you could delete the materials file, but then you lose so much info. you could also delete the parts of the materials file that refer to maps you can't find. ** when exporting the poser obj, I click off the universe first, then click on just the figure and the props that I need. transparency maps are still a problem, though. don't know how to easily do those yet. I hope it will be fixed in the next patch, for which we have to check the onelist Carrara message board frequently.
Hi I just got Carrara. Wow is this going to be a learning curve :( Anyway, I save a Poser fig in .obj from Poser 4. I import into Carrara. Loads in. NO textures! Change import settings. Starts loading. IMPOSSIBLE TO FIND FILE message. I thought it might be looking for textures, but it only allows for a .car file to be found. If I click cancel it loads. (sometimes canceling several times) What's going on? Please help. I would like to get some figs I did into Carrara to do some rendering. Is there a secret to this, that I'm missing? Should I trash the .mat file? James Any help is aprecieated.
