Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 5:49 pm)
I think the "as morph target" prevents scaling, positioning, and rotating. It only allows applied morph targets to pass through. I'm not sure about magnets, as I don't use them much. You can leave the "as morph target" unchecked, as long as you make sure the figure hip and body positions are zeroed.
When I try to export a morph target from Poser Pro Pack and have the moprh target option checked in the last dialog box, that when I go to check the OBJ that was created, what I get is the base figure with no morphing. But when I export it and dont check that box I get the OBJ as it should be. Isnt there something wrong here? Also I cant seem to keep magnets "invisible" even though I have unchecked the visible box in the properties dialog box. Thanks, David
