Sat, Jan 11, 7:47 PM CST
Subject: What constitutes "High Resolution"?
JettBoy ( ) posted Tue, 05 November 2002 at 7:03 AM · edited Sat, 11 January 2025 at 5:38 PM
Forgive my ignorance, but I work in print. High resolution for press is generally 300-400dpi at 100% physical (print) size (pixel size doesn't really mean anything). I've been doing my own texture maps for Poser and generally they look fine at 72-120dpi, but I've tried a few experimental maps with tattoos, and at that res they show up badly pixelated in Poser. If I save these maps at a higher res (400 dpi?..what?) will the problem get fixed? Will a higher resolution affect the size (pixel size) and cause mapping problems? Help! I'm beggin'...
Cheers ( ) posted Tue, 05 November 2002 at 7:44 AM
It's not DPI that counts JettBoy, but image size (i.e. 3200x2400, 1600x1600 etc.)...the larger the image size, the better the quality :o) Cheers
Twitter: Follow @the3dscene
hogwarden ( ) posted Tue, 05 November 2002 at 9:47 AM
Yep, the DPI setting only becomes important when you print the image... although most modern printer drivers aren't fussed as they re-size images on the fly. "Proper" printing equipment is more reliant upon the DPI, so if you get images printed professionally, you might need to supply them at a specific DPI. PC monitor DPI is static, depending upon the size of your monitor and resolution setting.
DraX ( ) posted Wed, 06 November 2002 at 12:53 AM
Yeah, if you're doing stuff for poser, only the DPI for the final rendered images matters, and only then if you're doing them for print. In every 3D application, the resolution of a texture is referred to as the per-pixel dimensions. A 512x512 iamge map is considered low resolution, where soemthing along the lines of 4000x4000 is high resolution. 1600x1600 can be considered high-resolution depending upon the detail is applies to to the mesh and the way the mesh is designed. High-resolution is pretty much a relative term in 3D depending upon what the mesh itself needs.
