Mon, Feb 10, 12:18 PM CST
Subject: How do you get trans maps made for poser characters to work correctly in 3dsmax
tooncy ( ) posted Fri, 07 April 2000 at 8:57 PM ยท edited Sun, 09 February 2025 at 11:32 PM
How do you get trans maps made for poser characters to work correctly in 3dsmax 3?
Roshigoth ( ) posted Fri, 07 April 2000 at 10:49 PM
Lets see.. Never actually tried it, but I believe I know how to do it. Try this and let me know if it works: In the Maps section in the Material Editor on the material applied to the object you're making a transmap for, find the "opacity" or "transparency" map spot (not sure which is there.. I'm going from memory right now) and click on the "None" button, it'll pop up choices. Pick "bitmap" and go find the transmap file. Set the strength to 100, and it should work. You might have to play with a few other settings to get results exactly like you want them, but the main thing should work for you. Like I said, however, I've never tried it, so for all I know I could be dead wrong, but it doesn't hurt to give it a try. =) Rosh
tooncy ( ) posted Fri, 07 April 2000 at 11:49 PM
It worked like a charm!) Thanks Rosh
Roshigoth ( ) posted Sat, 08 April 2000 at 12:35 AM
Cool, no problem. =) Rosh
Ede ( ) posted Sat, 08 April 2000 at 2:43 AM
cool, thanks rosh, that was helpful for me too :-)
