Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 11:58 am)
When you build your PHI file, make sure it has the same name as your obj file (except for the extension) and make sure it's in the same directory as the obj. Poser will often tell you it can't find the obj otherwise. Just thought I'd mention that since it took me a long time to figure that one out when I started building cr2s.
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Haven't been here for a couple of days, my cat died.Wasn't up to doing anything.My poser exe is in C/programs/metacreations/poser3. I did put it in there. Thats when the dialog box came up. Will try again, and maybe the obj name I changed and thats the problem. Will try tonight, will let you know.-Thank you all.
Downloaded Phi Builder 2 times, finally the 3rd time it "took". It said to put in the directory where poser 3 is installed. O.K.-Did that- C-program-metacreations. Not good! O.K.-tried c-program-metacreations-poser3. O.K. still not good.! even tried to put it in geometries! Still said that dialog box thing-then phi opend up, tried to use it anyway, but said obj couldn't be found, da! Downloaded 3 tutorials, even used a pre-made phi from elsewhere, but-Still that dialog box.What/where does it go, what am I doing wrong? Embarrassing.
