Mon, Jan 27, 9:15 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Subject: need help with this figure
MaDtrOll ( ) posted Sun, 09 April 2000 at 8:53 PM ยท edited Sun, 04 August 2024 at 11:06 PM
I am having serious trouble with this texture. you can see where the arms, hips and fit go together the texture isnt matching up. I thought that if I painted around what I had it would fill in but all ive got now is a big bunch of green on my texture and the same problem. BTW..the tattoo on the back is a modified design by Davo. help please
DEL ( ) posted Sun, 09 April 2000 at 9:48 PM
Have you altered the mesh? Like increasing the surface by enlarging the musculature. Try exporting the figure as an OBJ then map it with UVMapper save the texture and then compare that to the original map your using as a texture. this should show you if there are areas that aren't getting coverage from you current map.:)
MaDtrOll ( ) posted Mon, 10 April 2000 at 4:49 PM
actually this texture was originally dreated using a uvmapper map. and I am going way outside the map already.
