Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Bryce lightning is meat to allow network rendering fo bryce. That means that when you render one project you use Bryce lightning to render it with several computers at a time. This reduces the rendertime, but you need a network. I've heard that a lot of people don't know how to set up the render-network. Strangely I couldn't find any tutorials about networkrendering.
(_/)
(")(")This is Bunny. Copy and paste bunny into your
signature to help him gain world domination.
I have both my machines connected over a simple peer to peer via cross cable. I have assigned each a fixed IP address associated with the respective NIC's. Works a treat for file swapping and cross machine access. (W98SE) BUT I can't seem to get lightning to actually run. Gave it the associated machines IP addresses, told it for the server to render as well and tried to run. It just doesn't seem to transfer anything to the secondary, which sits idle. Any ideas what I could be missing?
Incarnadine - I have the same problem - I can set it all up beautifully, but it just won't connect to the other puter on the network - I get the symbol that means there's a problem with the connection, but have no idea how to resolve it. Which is a shame, because we have at least three 'spare' boxes here that I'd like to use as a render farm...
I've had up to 4 machines running using bryce lightning without a hitch. You need to make sure you have the latest update for for bryce 5 and the latest Lightning. Load Bryce and the br file on 1 machine then load and run Lightning on the others. I use a fast ethernet switch as a hub. Another thing to look for I believe depending on the network render settings and the type of render (animation or single frame) it handles the parsing of the frames and or tiles to one machine or more depending on these settings. In other words if you are doing a single frame render and you select (each machine should process a frame) Only 1 machine will process the render. Then theres tile Optimization so if you have a single frame rendor Bryce will send small tiles of the frame to be rendered to all the machines on the network. Hope this helps I guess I could to a tutorial hmmmm...
hi there. i have just downloaded the Bryce Lightning from corel site and i got no idea how to use it, some one know? 10x
