I guess I should explain the not revisitng it part, I was using open GL in bryce and evertime it crashed it corrupted the file, so I would have to use a previously saved (under different file name) and start over. Using direct 3d seemed to have fixed this, crashes were less frequent and it hasnt corrupted the file yet. However the saved state I have it in now has a totally different atmosphere then any of the pictures.
Umm.. you could really use some textures to bring this stuff out.. Everything looks blank... Also may want to make sure that Bryce's gamma correction is off. That usually helps, especially when working with Poser figures, as things look washed out when it's on. You might want some sort of scenery, even if it's just some volumetric clouds.. Once again, the scene just feels really blank. But maybe you wanted it that way. If so, nevermind. =) As for the bryce size, it's probably due to all the poser figs.. they'll do that. Rosh
Content Advisory! This message contains nudity, violence
